Bad Brakes on a Delta
Old Jun 30, 2008 | 01:27 PM
bcg88's Avatar
I need help diagnosing a brake issue on my 69 Delta. While stopped at a light I feel a very slight falling away of the brake pedal. If I pump the brake it stiffens right back up. It was so slight I was not sure it was happening. Over time however I am convinced it is. Also, I am not sure I am getting optimum braking power but have a tough time relating the power of the Olds brakes to more modern cars.
Second, last night I parked the car in the garage. After turning it off I realized I needed to pull the car further into the garage (occasionally I envy you A body guys). I fired her up and moved forward 6 inches or so. When I hit the brake it went all the way down. I let it out and hit it again and had firm braking power. Perhaps a vacuum issue??
Background: I have drum brakes all around with new shoes and wheel cylinders a couple of years ago. The master cylinder is currently full (I have checked it frequently after these issues) and there are no leaks that I can see but I have yet to pull the drums off. The power booster was replaced a couple of years ago as well. The current master cylinder was put on by a previous owner many years ago and is not stock.
Thoughts? Looking at my chassis manual makes me think I may have a bad master cylinder.
Old Jun 30, 2008 | 04:53 PM
Oldsmaniac's Avatar
I would say your master cylinder is bad.
Old Jul 1, 2008 | 07:44 AM
^^^^^^^^^^What he said. Unless you can see a puddle of brake fluid on the floor, this is the classic symptom of a bad M/C.
Old Jul 1, 2008 | 08:08 AM
bcg88's Avatar
Great guys. Thanks for the feedback.
I assume that the new MC needs to match the power booster (Bendix or Moraine). I don't know who made the booster?? It is silver, probably a reman unit. 1) does the MC need to match the booster? and 2) if so, how can I tell what I have.
Old Jul 1, 2008 | 01:20 PM
Oldsmaniac's Avatar
I believe there are 2 types of MC's as you state. Take your old one with you to be sure. If I remember correctly there is a different length brake pedal rod and perhaps diameter rod needed between the two. The booster will be the same.
Old Jul 12, 2008 | 04:51 PM
Kaline's Avatar
bcg88: You definitely have a bad master cylinder. To be sure you get the correct part, take your old master cylinder with you. Sometimes discount chain auto parts stores (like AutoZone, Advance, Checkers/Schucks/Kragen/Murray's) list the Moraine for automatic transmission vehicles and Bendix for manuals (although this is not always the case). Best of luck!
Old Jul 12, 2008 | 08:41 PM
bcg88's Avatar
Thanks for weighing in! After due diligence, I ordered one off Rockauto. It came yesterday and matches my current setup. I will install tomorrow. wish me luck!
odddoylerules
Apr 21, 2014 07:54 AM
72allblackcoupe
Apr 6, 2014 07:20 PM
airmale
Nov 13, 2013 11:15 AM
1carsick
Brakes/Hydraulic Systems
23
Oct 2, 2012 05:50 PM
russell-t
Apr 30, 2011 05:56 AM
