72 Cutlass Supreme front brake hose
Old Apr 28, 2011 | 04:33 AM
MJAKS462's Avatar
I am on my 2nd set of front disk hoses that I have ordered.
Both are to short and get tight when I turn the wheels all the way.
The last set from summit has a picture of what looks like I need Part # dhb-h73242 at Summit ) but they sent me shorter hoses without the metal line attached. They sent 12" hoses
anybody know what the correct lenth should be and where I can get the correct ones
72 Supreme convert
disc front , drum rear
Old Apr 28, 2011 | 06:23 AM
Rickman48's Avatar
Try 'The Parts Place' = might be a little pricey, but the correct parts are worth it, if you tell them exactly what you need!
Old Apr 28, 2011 | 06:52 AM
Tony72Cutlass'S''s Avatar
http://rockauto.com
They've got lots of options for all the parts you need, and i've been pretty happy with all the parts i've ordered through them, recently (coil, rotor, cap, plugs, wires, all for 60 bucks in ACDELCO parts) in fact i posted a bunch of discount codes somewhere on a thread around here not long ago too..
-Tony
Old Apr 28, 2011 | 06:57 AM
Lady72nRob71's Avatar
What they say is correct is often only as correct as they make it.
Been there done that. Biggest arguements i ever did, despite my goals to never argue with idiots...
As for the hoses, all of the ones I ever installed on the fronts always look and install as if they are a bit short, but they have always worked so far...
mcox8051
Jun 20, 2015 04:51 PM
Sampson
Mar 24, 2015 09:33 AM
68RocketAction
Jan 2, 2014 06:49 PM
Del70
Aug 2, 2012 03:39 AM
scubastever
Brakes/Hydraulic Systems
Sep 24, 2010 11:33 AM
