72 and 78 cutlass squeek on passenger side
Old Feb 6, 2007 | 05:20 PM
cutlassdriver61's Avatar
I used to have a 78 cutlass and I now have a 72 cutlass. Both of them developed a loud squeek on the passenger side front end. Has anyone had this issue? What would I need to do to fix it? I'm not well informed in the suspension area of the car. Any info would be appreciated!
Old Feb 7, 2007 | 04:58 AM
Oldsguy's Avatar
Past Administrator
Try jacking the car up and placing a good jack-stand under the corner for safety and then move the suspension around some, jiggling the wheel, etc. I would guess it would be a bushing on the shock or the tie rod end or something similar.
Old Feb 7, 2007 | 05:10 AM
texasred's Avatar
Tom Servo's Stunt Double
I chased a squeak on my 71 for months. It turned out to be....bumper support bolts that "seemed" tight.
Bounce the car up and down on the fender and then the bumper. You'll know.
C.J.
Old Feb 8, 2007 | 05:17 AM
OldsMotion's Avatar
OldsMotion
I had squeaks in my 79 Cutlass..it turned out to be a bad sway bar bushing. You cannot find it with it jacked up on stands if that is the problem. There needs to be weight on the wheels
John
Old Feb 8, 2007 | 07:52 PM
mitsudave's Avatar
Yeah, like everyone else said, it could be anything...I had a squeak in the front of my 69 Cutlass that turned out be the upper control arm bushings. Front end squeaks/clunks/moans/groans can be difficult to track down. Put it up on jackstands and start moving things around.
Old Mar 9, 2007 | 06:07 AM
Jim's rare 80's Avatar
Jim's rare 80
Hi. A quick fix for a loud squeek on the passenger side of any car is to leave the wife at home when you go crus'in. LOL. Just kidding. If you haven't already found the problem yet, be more descriptive on when it happens. (constant, turning, braking, etc.) Suspensions are my thing. (so my friends tell me). Let us know if you fixed it. It may help others seeing what you found. Thanks, Jim
KZ442
Nov 16, 2014 06:19 AM
rmsikorski66
Sep 8, 2013 12:58 PM
75cutty455
Aug 23, 2011 10:08 AM
f-85
Nov 27, 2010 05:25 AM
