71 cutlass master cylinder to pro portioning valve
Hi Guys,
Helping my son with his car and we ran into a problem. I need a drawing, or exploded view of the master cylinder to the pro portioning valve line routing.
We are installing a in line tube disc conversion kit, very little issues, but ran into this. Any help would be much appreciated.
Thanks, mike
Thanks, mike
Hi Guys,
Thanks, mike
Thanks, mike
Frankly, the lines really only go on one way. The threaded fittings are different sizes (at least, they are on OEM hardware). Rear port on the M/C goes to upper rear port on the combo valve (next to the differential pressure switch terminal). Front port from the M/C goes to the upper front port on the combo valve. Rear brake line goes out the back of the combo valve to the axle. Two front lines come out the front of the combo valve.
Joe,
I have the stock kit brass valve mounted on the frame rail. What I need is a picture of the supply lines off a 71 to see how they "flow" or lay if you know what I'm saying. I have gained Aton of knowledge on Oldsmobiles on this site and I see you everywhere out here. Thank again for sharing the knowledge . -Mike
rwtrader
Jan 11, 2012 09:33 AM
veltboy618
Brakes/Hydraulic Systems
Jul 14, 2011 07:10 PM
1k442
Nov 30, 2009 12:37 PM
