70 olds master cylnder
Old Jun 7, 2015 | 01:50 PM
mitchy's Avatar
I got all my brake components on and I went to bleed them and all of this black gunk came out of the master cylinder, do I clean it out or buy a new one?
Old Jun 7, 2015 | 02:23 PM
At a minimum, flush the system out, but frankly a new M/C is cheap and you have to bleed the brakes anyway, so you MIGHTASWELL...
Old Jun 7, 2015 | 03:43 PM
bob p's Avatar
Rocketeer
I just went through the same thing... I thought about doing a MC rebuild because the original reman for my 62 was sort of expensive. I ended up deciding that I was better off replacing all of the hydraulic components and switching to a dual-pot master. Then, after I replaced all the hydraulic components, I decided that those old lines were just going to release grunge into my new hydraulic parts, so I ripped out all of the lines and replaced them too.
If the only difference between a near-total rebuild like you're describing and a total rebuild is doing the lines, then I'd think about doing the lines too. FWIW I just finished using the "NiCopp" brand of nickel-copper-steel alloy lines to do total rebuilds on two cars and it was a very pleasant experience -- that's a sharp contrast to all the unpleasant experiences I've had with steel lines.
oldsladyliz
Jul 18, 2009 04:10 AM
oldsladyliz
Mar 24, 2009 11:21 AM
maraz52
Aug 15, 2008 09:24 PM
Olds57rocketgal
Nov 22, 2007 10:02 PM
<marksz71>
Brakes/Hydraulic Systems
Oct 20, 2006 07:14 PM
