68 ninety eight distribution block.
Old Apr 25, 2023 | 07:52 PM
Brodewok's Avatar
82 ninety eight
So I can't get the back brakes to bleed. New shoes, rubber hoses, cylinders, master. Bench bled. Then attempted to bleed the system. I can't get anything to the back with a vacuum pump. The front will bleed but not as good as I would like to see.
I suspected a stuck proportioning valve. But then realized it's a distribution valve and if I'm correct there isn't any moving parts to go bad in there. Also the brake warning light flickers instead of staying on like a proportion valve should.
Clogged rear main line maybe? Externally it looks good. No rust or anything.
I might just disconnect the rear line at dist to the rear rubber and try to blow through it.
Thoughts?
Old Apr 26, 2023 | 03:40 AM
The distribution block has a sliding piston that is the contact for the differential pressure switch that operates the BRAKE light. It can get stuck or clogged with debris. Before that, unscrew the rear bleeders and check that they are not clogged with rust.
Snake Oiler
Brakes/Hydraulic Systems
Apr 27, 2020 07:57 PM
1arunem
Aug 21, 2017 05:20 AM
rothlane'68
Jul 10, 2016 05:24 PM
72CS
36
Mar 30, 2013 05:58 AM
1970442w30post
Jan 20, 2011 05:06 PM
