65 Starfire brake booster interchangeable 88/98 ?
Hi guys: New owner of a 65 Starfire that sadly needs a power booster. I have been doing some searching through local suppliers, and Cardone has listing for the 88/98 but not for Starfire. Now I was thinking that these three have so much in common brake wise, that I could likely use the 88/98 one. Has anyone tried this or found a better solution? I appreciate any help you guys can advise.
Cheers!!
Plasma98
Cheers!!
Plasma98
Just be careful about the pushrod length where it presses on the master cylinder piston. The single master cylinders (66 and older) use a longer pushrod than the dual master cylinders (67 and later). The two are not interchangeable.
Thanks Joe. every bit of info is welcome. Have ordered the 88/98 booster, and surprisingly they had stock in Canada! Heheh..what a coutry <grin>
I'll let you guys know how the final out come goes...then its power frigging window repair time.
Cheers
Plasma98
Cheers
Plasma98
zodiacblueS
Brakes/Hydraulic Systems
44
October 12th, 2014 03:22 PM
formula
March 22nd, 2009 09:46 PM
