4 wheel drum brakes
4 wheel drum brakes
I had a leaking master cylinder and replaced it, bench bled it, and the bled the wheels. I had a very stiff brake pedal and seemed like they were manual brakes. There was a lot of paint missing on the booster from the master cylinder so I just replaced the booster and still have the same problem. Almost need both feet to stop. Should I try bench bleeding the master cylinder again?
A quick easy check of the booster can be achieved by depressing the brake peddle hard, then start the car. if the peddle compresses another 1/4 inch the booster is working, if not look some where else for the problem....Tedd
455Olds
Brakes/Hydraulic Systems
December 8th, 2013 08:16 PM
Oldssupreme
January 29th, 2013 07:03 PM
1carsick
23
October 2nd, 2012 05:50 PM
