1987 delta 88 rear brake question?!
ya i got 87 delta 88 royal brougham
has drums in rear and i was wondering if there was a conversion kit to put discs instead of the drums? Or if a newer/older olds setup would work in the drums place?
This car is not exactly mainstream. I would be absolutely amazed if there were a kit available. On the other hand, thanks to GM's parts-bin engineering, you are in luck. Your H-body shares rear wheel hubs with the 1986-1991 Cadillac Seville. The Sevilles were offered with four wheel disk brakes, so you can grab a set of those (along with the master cylinder and proportioning valve) and bolt them to your Olds. The only wrinkle may be if your car has ABS.
delmontcrusier
May 28th, 2023 07:37 AM
Kilmster
Brakes/Hydraulic Systems
August 6th, 2014 05:41 PM
