1970 Bell drum brakes - Stampings/Marking
Old Dec 16, 2025 | 05:43 PM
v8al's Avatar
Registered Olds Owner
Was cleaning up a set of 1970 442 rear bell brake drums and noticed some markings, etc and thought I'd post some pics/thoughts.
You can see some of the original green paint on the rims, the manufacturers name: Centrifuse, 35454 which I am guessing is a part number and an A with a 0 under it. I'll guess that translates to A=January 0=1970 which fits with a February 23, 1970 build date.
Any thoughts on if my "A0" translation is correct?
Old Dec 16, 2025 | 09:26 PM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Centrifuse refers to a spun cast process that marries the cast shoe lining to the steel bell.
The circle MW = Motor Wheel co.
The 35454 = part number for std 9 1/2 x 2" bell drum and is/should be the original drum for your car.
Availability started the same time the O rear end became available, 1967 through 70... Cutlass/442, except wagons.
The Oshawa cars with the Chevy rears did not get the bells.
I've heard a couple of meanings for the Ao:
Assembly outboard (drum) which makes little sense, to me.
Assembly Oldsmobile, plausible as the bells were exclusive to Olds.
An OEM quality stamp, plausible.
I researched this YEARS ago as my 68 has these drums and the car is painfully original.
Last edited by droldsmorland; Dec 17, 2025 at 05:58 PM. Reason: cant spell to save my life!
Old Dec 17, 2025 | 03:47 AM
Tri-Carb's Avatar
Perhaps A.O. Smith Company made the core. They made frames and brake drums. "A O" could be the logo used at the time.
Old Jan 10, 2026 | 02:17 AM
OldOldsLover's Avatar
Hi,
did you happen to weigh, or know the weight of these drums compared to the finned drums?
Or even a rough idea from anyone?
Thanks in advance
cheers
Update for Answers I think are correct.
Regular Finned Drum 16.5 lbs
Bell Type Drum 12.5 lbs
bdub217
Brakes/Hydraulic Systems
54
Aug 19, 2025 05:17 AM
Bfg
Feb 22, 2024 07:09 AM
Catdaddy1971
May 29, 2022 02:48 PM
Vader
Oct 25, 2021 04:07 AM
rallyredw31
Feb 11, 2019 02:24 AM
