1970 442 brake line clips
Old Jan 16, 2025 | 09:55 PM
dragline's Avatar
Is this color coded brake line clip kit correct for a 1970 442? Also is the diagram correct concerning the center clip for a Lansing built car?
Picture 1 of 9
1970 442 cutlass W-30  W-31 Brake line clips   colors - Picture 2 of 9
Old Jan 18, 2025 | 08:33 AM
WTHIRTY1's Avatar
Escape From The Ordinary
What do you mean by center clip?
Yes, those are correct with the exception of the "grasshopper" clips having ILT stamped on them. Try to reuse your original bolts if you can as the repops here won't have the correct marking on the head.
Check out my W-31 restoration for the details on the brake clips.
Old Jan 20, 2025 | 12:13 AM
dragline's Avatar
The center clip I was referring to is the highlighted FIGURE 1 (Lansing Plant Only) center frame clip.
Old Feb 15, 2025 | 11:59 AM
WTHIRTY1's Avatar
The yellow clip from ILT is correct in your picture.
Ikesgotav8
Brakes/Hydraulic Systems
Oct 13, 2024 06:08 PM
paulolds
May 25, 2022 12:48 PM
oldzy
Nov 27, 2010 08:54 PM
Eddie Hansen
May 4, 2010 09:45 AM
oldzy
Apr 24, 2010 09:13 PM
