1969 Cutlass Brake issue
I have a 1969 cutlass with a new brake issue that I have been having a problem in resolving. I began noticing after driving my vehicle about 20 minutes, The front brakes were engaging. I have replaced the front brake hoses, the calipers, flushed the lines and replaced the brake fluid, (old stuff was brown)I took the master cylinder off and checked the pin, which is not adjustable. The master cylinder and power booster were replaced about 5 years ago. The issue appears to be heat related. I have parked it in the driveway running about 20 minutes and the front brakes are locked up. Let it cool and they are free again. I even tried backing off the bolts on the master cylinder and pull it away from the power booster. Same results. It appears that I have a distribution block for the disc/drum brakes. Do they go bad ? I have been driving the car for the past 5 years with no issue. HELP
Just to be clear:
The problem is new without any recent brake work, correct?
And,
The brakes will seize up with the car just idling for twenty minutes, correct?
If a front bleeder screw is opened is there pressure and does that wheel release after the bleeder on the caliper is opened?
And,
Something may be preventing the brake pedal or the booster from fully returning to the retracted position. When the brakes are locked have someone pull the brake pedal to the up position while the cover is off the MC, watch to see if there is a surge of fluid from the holes in the bottom of the MC reservoir. If the piston in the MC isn't able to clear the holes in the bottom the brakes are held on. You should be able to see the edge of the piston seal move back and forth under the hole in the MC as the brake pedal is actuated. Hope this helps.
I believe I have found the issue. I had a recent oil change that resulted in an overfill of motor oil. This resulted in excessive heat from the engine. I have changed the oil to the proper level and now the problem has disappeared. The oil level was about a half of a quart over full. After researching excessive heat if oil level was overfull. I found that it does produce excessive heat. The heat apparently effected the pressure in the brake system.
Thank all of you for your input
The consistent issue has resolved after changing the oil to the proper level. I would have never thought that it would have been the problem. I am estimating that it was a half of quart it may have been more.
The whole problem was heat generated. under the hood, If I would start the vehicle with the hood down. in about 15 minutes the front brakes would lock up. I would open the hood and the brakes would free up after a few minutes. Even not driving the car and letting it sit there. I have changed everything to include front hoses, calipers, master cylinder, thermostat and replaced the brake fluid. The only thing that was done before this happened was top hose and thermostat replacement and an oil change that was over filled. The thermostat change did nothing. The oil change to the correct level alleviated the brake issue. Research on the internet indicates overfill on the motor oil increases heat. I changed it and it worked. After changing all the brake components, i figured it had to be something else. This is when I realized the oil change was done. I checked and it overfilled. It is the craziest thing I have ever experienced in a 60 year lifetime of working on cars.
