1967 Cutlass CS Front Disc Brake Conversion
Old Apr 3, 2018 | 06:58 AM
babailey's Avatar
I have a 1967 Cutlass CS Holiday Coupe with power drum brakes. I would like to convert the front to disc. Do I need a new brake booster and master cylinder, or can I use the current ones if they are still operational?
It is only about $200 difference in price, so should I just suck it up and buy the conversion kit that has a new master cylinder and 11 inch AC Delco booster?
I think my real worry is what it takes to install a new booster.
Thanks!
Old Apr 3, 2018 | 08:15 AM
lemoldsnut's Avatar
Your booster will work but not the master.
If you use 69-72 disc brake parts you can get it all on rockauto.com and save even more.
Changing a booster is actually very easy. 4 nuts on the firewall side and a pin inside as well as the lines to the master and you are done.
Hope this helps
Larry
Old Sep 14, 2018 | 04:45 PM
NiceOld(s)Car's Avatar
I was looking through and found this question about a 67 CS. I have a 67 442 CS that has manual 4 wheel drum brakes and I would like to convert to power and front discs. Is the same information above regarding getting 69-72 parts from rockauto.com still my best bet as well?
Thanks,
Jack
The Flash
Ninety-Eight
Feb 28, 2017 10:50 AM
Mr Shifty Sidney
Jun 22, 2014 09:48 PM
Mike Allen
Brakes/Hydraulic Systems
Jul 17, 2011 12:03 PM
1969w3155
May 20, 2010 10:26 AM
Vinny72olds
Apr 16, 2009 07:40 AM
