1956 Oldsmobile 98 Master Cylinder
Old Aug 17, 2011 | 04:03 PM
Joey Lights's Avatar
I have just received a 1956 Oldsmobile Holiday 98. I was going through the regular maintenance. The car has been sitting for about 4 years. The brakes were drained, all fluids replaced. The engine and transmission run perfect! It has the Rocket V8 and the Hydro-Matic transmission. the problem is the brakes. I went to fill up the brake fluid and the stem that holds the dip stick and attaches to the master cylinder broke off. It looks to be a pressure fitting. Any one have suggestions on how to fix? Can JB weld work? How hard is it it to replace the master cylinder? Is there some other plug to use.
Thank you in advance.
Any Help is greatly appriciated.
Joe
Old Aug 25, 2011 | 03:41 PM
317rcampbell's Avatar
I rebuilt my master cylinder and got the kit from Fusick.com. It is pretty simple to get the master cylinder off . I would give them a call .
mbat
Brakes/Hydraulic Systems
Apr 12, 2021 07:40 AM
AndyBee
Jul 17, 2010 09:52 AM
Chumley
Oct 31, 2007 09:17 PM
<marksz71>
Oct 20, 2006 07:14 PM
martine
Feb 5, 2004 10:28 AM
