Body work
65 Cutlass vent window repair
Body work
All body work discussion including vinyl tops
Apr 11, 2012 | 07:03 PM
dingusboy
Jan 2009
Chicago suburbs
Any tips and/or advice on removing and replacing worn vent window latches on a 65 Cutlass?
dingusboy
Find More Posts by dingusboy
Apr 11, 2012 | 07:10 PM
gearheads78
car guy
Apr 2008
Dallas TX
Quote:
Originally Posted by
dingusboy
Pretty straight forward. You have to push roll pin out first and then you will see the nut that holds the rest together.
gearheads78
Find More Posts by gearheads78
Apr 12, 2012 | 04:30 AM
dingusboy
Jan 2009
Chicago suburbs
Thanks Gearheads. Do you use any lubricant to help pull it off the glass without causing any damage?
dingusboy
Apr 12, 2012 | 06:46 AM
gearheads78
car guy
Apr 2008
Dallas TX
The ones I have done were not rusty and came right apart.
gearheads78
hot air coming out the bottom vent and cold air out the top vent? 84 delta 88
84oldsDelta88
20
Jan 12, 2016
01:36 PM
66 cutlass vent window assembly removal
halffast
03:15 PM
65 Cutlass vent window latch
dingusboy
06:14 AM
68 cutlass vent window
billykissell
07:29 PM
71 Cutlass town sedan vent window molding
jeffery47
07:07 AM
Body work
Cutlass door skin on a chevelle door?
04:16 AM
