68 Hood Hinges
Old May 14th, 2016, 03:23 PM
dmberendsen's Avatar
68 Hood Hinges
My body guy said I needed a new set of hood hinges for my 68 Cutlass "S" convertible. Since there doesn't seem to be any repos I ordered a used set from what I consider a reliable source (The parts place). When they arrived we compared them and found the used ones from The Parts Place to be much beefier with larger springs than what I presumed was the originals that came with my car.
Was there an aftermarket source or two types available depending on model?
dmberendsen is offline
Old May 15th, 2016, 05:48 AM
65Delta's Avatar
How far did your hood open with the old hinges? One of the big complaints about the '68 was that the hood didn't open far enough (in degrees) to allow easy access to the engine bay. The hinges were redesigned for '69 to allow the hood to open further. The later hinges can be retrofit to the '68s and most people like the additional room. I bet they sent you a set of '69+ hinges.
65Delta is offline
Old May 15th, 2016, 07:32 AM
69-72 hinges won't bolt to the 68 fenders unless you have the replacement fenders with both bolt patterns or you modify your originals to accommodate the different bolt pattern on the hinges.
FYI, while 1968 hood hinges are one-year-only, all RWD Oldsmobiles used the same hinges that year, so full size cars are also donors.
joe_padavano is offline
Old May 15th, 2016, 08:50 AM
Senior Moment Member
z11375ss's Avatar
Wear a hardhat. I'm telling you.
z11375ss is offline
Old May 15th, 2016, 08:57 AM
Kennybill's Avatar
I have 1967 Oldsmobile 88/98 hinges. I'm not sure if this works.
Kennybill is offline
Old May 15th, 2016, 08:07 PM
I should take pictures for comparison. I do believe the beefy hinges will open a bit further but not by much.
I agree a hard hat would be good advise.
Old May 15th, 2016, 08:09 PM
Randy C.
rcorrigan5's Avatar
In reality, '69 didn't do much better. Yes, the hood opens a lot higher but the designers, in their infinite wisdom, put on that nose that hangs down from the front middle of the hood. Catches the back of my head almost every time. Yes, a hardhat is in order!
Randy C.
rcorrigan5 is offline
Old May 16th, 2016, 07:29 AM
lemoldsnut's Avatar
I can do the 69 hinges if you decide to go that route.
Email direct to lemoldsnut@aol.com
or calls west coast time 8 am to 8 pm 541-815-4363
Larry
lemoldsnut is offline
Old May 16th, 2016, 09:37 AM
Octania's Avatar
Hinges are the same, but I believe that the springs vary from model to model. Easy change.
'68 springs are NOT the same as 69-72, one of 100's of 68/9 diffs. End loop orientation- I think '68-only are at 90 degrees to one another. Or, vice versa.
Octania is offline
georgiaboy697
July 2nd, 2010 09:23 PM
Eightupman
February 1st, 2010 10:23 PM
Jolly Green
August 2nd, 2008 12:51 PM
chuffman
June 6th, 2007 09:23 PM
Quick Reply: 68 Hood Hinges
