What is the inside of the trunk suppose to look like?
Old April 28th, 2017, 07:37 AM
Ghunter's Avatar
So another question here.
EDIT: This is for my 72' Cutlass Supreme Holiday.
I'm wondering what pieces I'm missing for the trunk, my bottom fenders beside the trunk is rusted out so I will be replacing that along with the outer and part of the inner wheel house. It looks like those all close up at the bottom of the fender.
But I'm wondering what piece fills in the trunk on the right and left side corners? The trunk pan just stops as circled.
Thanks in advance!
Ghunter is offline
Old April 28th, 2017, 07:43 AM
Olds Fever
CRUZN 66's Avatar
If I remember correctly, nothing fills that void... The quarter panel wraps down and back up to the trunk floor... It's a area where dirt and other junk collect when left on the trunk floor...
CRUZN 66 is offline
Old April 28th, 2017, 08:01 AM
Dave26's Avatar
X2 with Cruzn, my 72 has had no body work, and looks much like yours.....btw those "wells" become the "black hole" for everything you can't find when you come home from the grocery store
Dave26 is offline
Old April 28th, 2017, 08:09 AM
Ghunter's Avatar
Interesting! Well that solves my problem! Thanks a lot!
Ghunter is offline
Old April 28th, 2017, 01:04 PM
And where I stuff an antifreeze jug of water for emergencies, and a scissor jack so it doesn't slide around, and just about anything else that will kinda-sorta fit in there. Most stuff is jammed in the well and leaned forward so it's held in place between the fender and that big lip on the wheel house.
Fun71 is offline
Old May 1st, 2017, 08:03 PM
cherokeepeople's Avatar
on the big b body cars they have a piece that covers that gap.
cherokeepeople is offline
Old May 1st, 2017, 09:18 PM
On the A-bodies, that space is a perfect place to keep your spare fan belts, distributor cap, rotor, points, condenser, and other items noted above, plus a bunch of tools you may never see again (sledgehammer, breaker bar, ratchet, spare sockets, etc...) and still have the "normal" amount of trunk space you had before.
MDchanic is offline
Old May 2nd, 2017, 05:06 PM
Yellowstatue's Avatar
Actually, that piece is called a Compartment Pan Filler. It is a vertical piece that connects the trunk floor with the bottom of the quarter panel...goes from tail light to wheel well. PN 9816631 & 9815057 '70-'72 all exc.wagons...try that.
Yellowstatue is offline
Old May 2nd, 2017, 11:47 PM
RocketRonnie's Avatar
Looks normal. Some have drain holes in the bottom make sure they are open. It's a good place to keep your gas money. Mine usted to be for spare tools and toilet paper just for when nature calls. One must be ready for the call.
RocketRonnie is offline
Old May 3rd, 2017, 03:22 PM
all my cars have a roll of toilet paper.
Old May 3rd, 2017, 07:00 PM
Tedd Thompson's Avatar
Or the multi task obliques role of paper towels. Don't get caught without them.... Tedd
Tedd Thompson is offline
phillipm
June 23rd, 2015 12:29 PM
Wise Performance
December 17th, 2013 05:19 AM
Rocket 442
November 3rd, 2013 04:03 PM
guy.graziano
Paint
January 18th, 2012 07:26 AM
emdesign
June 12th, 2011 09:29 AM
Quick Reply: What is the inside of the trunk suppose to look like?
