Shimming hood
Old Mar 15, 2016 | 08:01 PM
woodie582's Avatar
Shimming hood
Is it acceptable to shim between the hinges and hood. Both rear corners are low in realation to the fenders. Installing the inner wheel wells changed the alignment. Thanks
Old Mar 15, 2016 | 08:14 PM
oldspackrat's Avatar
It is acceptable & more common than you might think. I have seen many hoods that have had a large short shim at the rear hinge bolt location. If it is vital that you have original parts I might be able to find one in a day or three.
Old Mar 15, 2016 | 08:23 PM
I find these on there all the time.
https://www.opgi.com/cutlass/C240503/
Old Mar 16, 2016 | 06:24 AM
Those aren't shims. Those are spacers that are used on EVERY Cutlass hood. They fill the gap between the hood hinge and the underside of the hood at the back of the hinge. For some reason, the hinge bracket has a dip in that area, but the mating surface on the underside of the hood is flat. If these spacers weren't used, you'd crush the hinge bracket when you tightened the rear bolt. These are not adjustments, there are mandatory.
The fitment of the rear of the hood is adjusted by loosening the bolts that hold the hinge to the fender and pivoting the hinge clockwise or counterclockwise to raise or lower the rear of the hood.
Old Mar 16, 2016 | 06:27 AM
Note the joggle at the rear of the hinge in these photos:
Old Mar 16, 2016 | 12:12 PM
woodie582's Avatar
Thanks all, and yes mine are missing and crushed.
Old Mar 16, 2016 | 12:19 PM
Originally Posted by woodie582
Thanks all, and yes my are missing.
Yeah, if you don't realize they are there, they often jump out as soon as you loosen the rear hood bolts and wedge themselves between the inner fender and firewall. Do NOT ask me how I know this.
I'm guessing that's why the repro houses sell them.
Old Mar 16, 2016 | 03:36 PM
woodie582's Avatar
Thanks for the lesson Joe.
Old Mar 16, 2016 | 03:40 PM
I knew that most had them but not the why. I always thought they were shims, thanks for clearing that up for me.
Old Mar 17, 2016 | 09:07 AM
Someone needs to clear it up for me. Those spacers always seemed like an "Oh, $h!t" fix for a design screwup.
Old Mar 17, 2016 | 10:52 AM
Opgi states
Quote "Necessary for hood alignment For all ’68-72 Olds Cutlass
Rear spacers fit between the rear of the hinge and the hood and are a must-have on all 1968-72 Cutlass vehicles. The spacer keeps the hinge in the correct location for the proper hood alignment. Spacers are approximately 1/4" thick steel and are sold as a pair."
Old Mar 17, 2016 | 11:44 AM
Opgi states
Yeah, the OPGI website also says this for their headers:
Originally Posted by OPGI
Cutlass Headers, Olds 400-455, by Doug's Headers
NOTE1:
These do not fit Cutlass Supreme.
OPGI's catalog isn't a Chassis Service Manual or factory parts book. The text TECHNICALLY isn't incorrect - these spacers ARE mandatory to use on the hinges that have that offset in the attach flange. I take exception with the term "shim", however, which implies adjustment. There is no adjustment here. You MUST use the spacers. I put these in the same category as the PS pump bracket spacers, for example. Those aren't "shims" either.
Old Mar 17, 2016 | 01:08 PM
m371961's Avatar
Never heard the term"joggle" as a noun. Is this a aerospace term?
Old Mar 17, 2016 | 01:18 PM
coppercutlass's Avatar
Chevy budget Olds powered
Are they needed for 72?
Old Mar 17, 2016 | 01:29 PM
Yes, actually. It refers to an offset, usually in a machined or formed part.
Do your hinges have a joggle?
Old Mar 17, 2016 | 01:50 PM
Idk I asked because I never paid attention and I have my hood lined up pretty good. Lining up panels on new cars is cake walk compared to old cars. The level of adjustment is beyond what modern cars have. I guess we have better tolerances in manufacturing nowadays.
Old Mar 17, 2016 | 01:54 PM
Again, those spacers aren't for alignment, they're to prevent crushing and distorting the flange on the hinge. And yes, manufacturing tolerances are a lot tighter now.
Old Mar 17, 2016 | 01:59 PM
I missunderstood what they where for.
Old Mar 17, 2016 | 04:15 PM
m371961's Avatar
Thanks Joe, you always teach me somethin.
Old Mar 23, 2016 | 06:10 PM
woodie582's Avatar
Well installed driver side spacer and tightened bolt no problem, pass side not so good, bolt is stripped. I assume from painter torquing the bolt without the spacer. Any thoughts on possible fixes without removing hood.
Old Mar 23, 2016 | 07:39 PM
Mine broke out so I welded a nut in mine before it got painted. You might see if yours can be tapped to a larger diameter bolt, perhaps metric.
Old Mar 23, 2016 | 08:08 PM
Re thread to a slightly bigger metric size. Some would hate the idea but it's the easiest cheapest fix.
Old Mar 24, 2016 | 03:58 AM
rcktdoc's Avatar
I have helicoiled them
Greg
Old Mar 24, 2016 | 05:51 AM
Greg
^^^This. If the nut isn't broken out, install a helicoil.
Old Mar 24, 2016 | 08:31 AM
woodie582's Avatar
Nut is not broken out. My thought was to try the repair with the hood on, there is 4" of clearance hood to spring.
Old Mar 29, 2016 | 05:27 PM
woodie582's Avatar
Heli coil in, spacer and bolt tight. Thanks all..
Arrowstorm
Jan 27, 2015 03:38 PM
chasman414
Feb 11, 2013 10:43 PM
georgiaboy697
Jul 2, 2010 09:23 PM
Gary Lagacy
Sep 20, 2008 01:35 AM
scubastever
Jun 25, 2008 11:33 AM
