Seam sealer
Old May 18, 2025 | 02:12 PM
Chuxter's Avatar
1970 Cutlass Supreme
Seam sealer
What is the best seam sealer for between the quarter panel and the panel below the window on a 1970 Cutlass Supreme?
Old May 19, 2025 | 05:23 AM
OLdGreenPaint's Avatar
If you mean the access panel attached with four screws, I think olds factory used butyl tape. It will seal it up quite well, but still allow panel removal if needed. Sometimes takes a little pry bar to do it
Amazon Amazon
If you mean something else, 3M makes several varieties, most catalyzed, that would be considered a permanent joint. Set up time is about a half hour, or thereabouts.
eh70
Body work
Oct 9, 2024 09:33 AM
wr1970
May 28, 2021 05:01 PM
m1369d
Body work
Feb 15, 2014 12:41 PM
oldstofty
Jan 19, 2014 01:08 PM
