Sanding advice needed.
Old Nov 15, 2015 | 11:59 AM
jankyrre's Avatar
I wonder how to sand filler on concave surface.As on the wheelarcs on a 68 Cutlass.I never get a result I am satisfied with.
Hope somebody will share their knowledge.
Old Nov 15, 2015 | 12:39 PM
68442's Avatar
You can get that foam pipe insulation in various sizes(Outside diameters) Wrap it in sandpaper. The insulation is flexable so you can bend it as desired. also you can cut it in various lengths depending on the result desired. This works well on those 68-69 wheel archs
Old Nov 15, 2015 | 01:37 PM
RandyS's Avatar
You can also use a piece of a swimming pool 'Noodle'. They are sometimes larger in diameter and can work great for an inside radius. There are also several very good tutorial videos on Youtube about sanding in tough spots.
Old Dec 31, 2015 | 03:01 PM
olwreckman's Avatar
There are various cardboard tubes available free, one I can think of is the tube in a used up masking paper roll. Also ,when making a first cut for shape as mentioned in previous post wrap the tube with 36 or 40 grit (sticky back) and cut the filler when it is green (semi hard). Once you get the shape the rest will be easier .
Old Dec 31, 2015 | 03:46 PM
coppercutlass's Avatar
Chevy budget Olds powered
I have soft foam sanding blocks to shape corners. For long countour surfaces I have foam blocks with rods inside of them to adjust the stiffness. Being creative is all part of it. I have been doing body work for 10 years and have made a bunch of my own tools.
Old Jan 1, 2016 | 07:00 AM
^^^This!
The fundamental rule is that the sanding block needs to match the curvature of the surface being sanded. You can buy a wide variety of contoured foam sanding blocks in various stiffnesses, or you can find materials to make your own. There is no right or wrong, do what works.
Old Jan 1, 2016 | 10:46 AM
These blocks are nice and work really well for finish sanding like over contoured 1/4 panels etc etc. I have 2 of them and well worth the money. http://www.eastwood.com/27-inch-adju...le-sander.html
Fakser
Paint
Dec 4, 2010 02:36 AM
CaliBoricua
Body work
Sep 27, 2010 11:38 AM
redvettemike
Paint
May 3, 2010 02:57 AM
6588
Aug 4, 2006 07:10 AM
SuperSickBoy
Jun 26, 2006 07:06 PM
