sagging doors on 68 convertable
Old Apr 26, 2009 | 10:20 AM
pakrat's Avatar
The driver's door sags a little and I need to pull up on the handle while closing the door. Will new hinges correct this or are the several different things that could be wrong?
Old Apr 26, 2009 | 12:10 PM
68/70 Cutlass's Avatar
You may get away with just pins & bushings. Are new hinges available?
Old Apr 26, 2009 | 12:32 PM
pakrat's Avatar
Saw new hinges in Year one.
Old Apr 26, 2009 | 12:39 PM
Aron Nance's Avatar
Pakrat; nice "S"! We have one that looks very similiar, called Big Red. A good body shop man can probably readjust your driver's door fairly easily. I would strongly suggest (unless you have the experience to do so) to have it done; you can mess it up more so. Experience has taught me a lot over the years, needless to say.
Old Apr 26, 2009 | 01:38 PM
ThyPlumber's Avatar
There is a bushing that needs to be replaced
Very easy job to in the driveway Have a buddy help you, easier with two people. I know the Parts Place in Elburn IL has a kit, I have bought it, think it was like 20 or 30 bucks.
Old Apr 26, 2009 | 01:52 PM
old98owner's Avatar
A fast way to tell if this is a big problem or a little one is to open the passenger door and see if it does the same thing. If it does then you might have a rusted through frame.
If the passenger door is OK then you need to replace or rebush the drivers' door hinges.
Be careful if you do this yourself. Doors are very heavy and clusmy when you are dealing with them off the car.
Replacing hinges and bushings on two door cars is a common thing as they have so much weight to support. Mercedes even made some 1960's two door cars with aluminum doors to make the hinges last longer.
Old Apr 26, 2009 | 02:00 PM
ThyPlumber's Avatar
Easy fix
Easy fix in the drive way, I got a kit from The Parts Place in Elburn, IL have a buddy help you with it. It only took us 20 minutes for both doors they line up perfect.
Old Apr 26, 2009 | 02:32 PM
pakrat's Avatar
Thanks for the info. It's just the driver's door that sags a bit, but it bothers the heck out of me.
Old Apr 29, 2009 | 05:11 AM
wolfman98's Avatar
Captain of my ship
Smile Easy to check
Get a buddy to help by lifting up uo the bottom end of the door while it's open. You can look to see if it may just need just the kit as bushings are the most common reason. That would be why it is only the driver's door as it would have been open and closed 5 times as much as passenger side.
Old Apr 29, 2009 | 06:52 AM
bittersweet71's Avatar
Fusick has those kits for $8.50 per door!
Old Apr 30, 2009 | 02:42 AM
wolfman98's Avatar
Captain of my ship
cheap
Teah and it would be a cheap fix , but I learned the hard way that it is a 2 man job and that was on a small car.
Old Jul 10, 2009 | 02:40 PM
tpawlik's Avatar
If you mark the original location of the hinge with masking tape, at either the jamb or the door, which ever is easiest to get at, it will make reinstalling the door a LOT easier. I know because I have done it both ways, with and without the tape!
Old Jul 10, 2009 | 02:53 PM
Redog's Avatar
Just make sure that the door lines up then.
I did this to my 92 Cougar back in the day
Old Jul 11, 2009 | 10:20 PM
ijasond's Avatar
Purveyor of Polyurethane
Sagging doors = rusted through frame?
I would not look at the passenger door to determine the best fix for a problem that exists on the driver door.
Doors are very heavy...
I'd say this is more likely to be the cause of the problem than a "rusted through frame"
Get the bushing kit, but in the mean time you can use a floor jack and a piece of 2x4 about 3 feet long to push that door up a bit(use the 2x4 under the bottom of the door to spread the load so you don't just bend the adge of the door). This may seem like a half-assed solution to the problem, but sometimes doors are so heavy that over time they sag, not necessarily as a result of bad parts. Anyone who has owned a chevy truck in the last 20 years probably knows about this. A door that's allowed to sag will end up damaging the latch, the striker, then it will start rubbing the top of the rocker.
halfmoontrail
Feb 22, 2013 12:14 PM
projectheaven
Suspension & Handling
Jan 4, 2012 09:32 PM
Olds Dad
Body work
Oct 15, 2010 11:50 AM
dallasite21
Aug 18, 2009 12:57 PM
case2273
Jul 16, 2009 02:02 PM
