Rusted Floor pans
Old Dec 22, 2009 | 09:11 PM
67Olds442X2's Avatar
Navy P-3 FE (Ret.)
Rusted Floor pans
I picked this car up a few weeks ago knowing that the floor had rust, didn't know how much until ripping up the carpet. My dumb question is this a prime example for pan replacement? The drivers side has no holes. I was hoping I wouldn't have to replace the floor, maybe just sand and patch the weak areas. This is going to be my "Driver", in good weather. I do need to track down the cause. Thanks.
Old Dec 23, 2009 | 05:44 AM
Ranzan's Avatar
Getting There
yes you can sand the floor and use a rust encapsulater on it like por-15
the usual cause for bad floors is leaking windshield or rusted window channel
If you get a flashlight and look up under the dash you can see the bottom of the front window channel and might give you a better idea if it rusted or not
Old Dec 23, 2009 | 06:13 AM
dc2x4drvr's Avatar
The 66-67 Cutlasses are famous for rusty windshield and rear window channel rust, pull the windshield to find and fix the holes. If your floor pans only have the holes shown, they can be patched by welding in new metal, but, if there are a bunch of pinholes, you will need to replace the panel to fix it right.
Old Dec 23, 2009 | 06:41 AM
66ninetyeightls's Avatar
Land Yacht Captain
pinholes are easy!!! Its noting 300-400 tac welds won't fix
Old Dec 23, 2009 | 07:35 AM
gearheads78's Avatar
car guy
Looking at the pics you are going to need to replace about a 2x2 foot section of floor. You have to have clean solid metal to weld to or you will be pulling your hair out.
As others said the source is more than likely the bottom of the windshield.
Old Dec 23, 2009 | 08:37 AM
slowolds's Avatar
Loose Radical
Depends on how thin the rest is. As Richard said about the welding. You need clean SOLID material.
Something that small I would clean/treat the rust and use Rust Encapsulator or Por-15.
I would guess the trunk pans are similar.
Do you want a little work or A LOT?
Old Dec 23, 2009 | 09:08 AM
Navy P-3 FE (Ret.)
Thanks for all the replies. The windshield and rear window are definitely leaking. The underside of the floor pan had been undercoated so it looked fine at first. Probably will replace the pan where needed. Thanks again for the input.
Dan
jon1957
Body work
16
Nov 2, 2018 09:10 PM
jasonjtrahan
Sep 18, 2007 09:54 PM
19594mydad
Jul 8, 2007 07:42 PM
bmwashington
Apr 25, 2007 10:21 AM
