Removing Trim
Old Feb 28, 2009 | 07:52 AM
desert442's Avatar
New 4-4-2 Owner
Removing Trim
What tools would be reccomended for removing trim, emblems etc??
I'm starting on the body work for my olds, and the first step is removing all of the fender badges, trim etc..
Any reccomendations?
thanks,
Old Feb 28, 2009 | 08:13 AM
thanks,
It depends on the car and the trim. Older cars use emblems held on with Pal Nuts on the backside of the fender. A wrench works fine (once the fender is off, of course). Newer cars have glued-on emblems. Stainless around the windshield and back window requires a special tool to release the clips that hold it in place. These are available at any auto parts store. Most other trim is held by a combination of metal clips with studs and nuts on the backside or plastic clips that snap over weld studs on the body. No special tools are required.
Old Apr 2, 2009 | 11:59 AM
buds68a77's Avatar
Joe,
Does this apply to the extra window and post trim on '68's?
Nothing special needed there as far as tools or tricks?
Bud
Old Apr 2, 2009 | 12:36 PM
I have used a paint sir stick to remove the chrome at the back of the hood. just carefully lay it flat and tap it off a little at a time.
Old Apr 2, 2009 | 03:27 PM
68Tom's Avatar
Originally Posted by buds68a77
Joe,
Bud
Bud, do you have a Sports Coupe? If so, be very, very careful with it because that stainless trim is impossible to find. I'm still looking myself.
All the other trim I found relatively easy to remove.
I learned a very good tip for removing the drip rail moldings. First, lay down a couple layers of masking tape over the trim. Then, take an old style bottle opener and use the little grabber to grab the underside of the molding. Then, gently pry up the bottom lip--as if you were "opening" a can of very old beer or oil. Work your way down the line, never forcing it and it'll eventually pop right off.
Old Apr 2, 2009 | 05:05 PM
buds68a77's Avatar
Thanks for the tips, I value others experience.
Yes it is a real '68 Canadian bench seat post 442 (now converted to 4 speed). I know what you mean about scarce, took over two years looking on e-bay to get replacements for my vandalized drivers side trim.
And I do have first hand technique with the can opener on many old STEEL canned BUD'S and Carlings Black Label.
Bud
Old Apr 2, 2009 | 05:59 PM
Ranzan's Avatar
Getting There
use a 1x4 on edge it works great
Old Apr 3, 2009 | 08:21 AM
citcapp's Avatar
Bud
Your age is showing
Old Apr 3, 2009 | 10:00 AM
Originally Posted by citcapp
Your age is showing
X2
"Church Key"
Old May 10, 2009 | 10:47 PM
Yellowstatue's Avatar
Smile Looking back
If you have trouble removing the door mirror, use a small block of 1 X 2 wood and tap the mirror base to the rear... I use the same tool as Tom for the drip rail but I put a 45 degree bend in the middle of the tool to make it easier to use and additionally wrap tape on the end that contacts the trim (extra precaution)...
Steve Wike
Body work
May 17, 2011 08:47 PM
ToroToro
Body work
Jan 28, 2011 11:28 AM
jensenracing77
Feb 23, 2009 04:19 PM
RWB
Dec 10, 2007 04:58 AM
cutthroat
May 14, 2007 02:39 AM
