Removing drop rail mouldings.
Old Aug 10, 2014 | 07:30 AM
jankyrre's Avatar
Seeking directions on how to remove the drip rail mouldings without destroing them.
Old Aug 10, 2014 | 08:35 AM
Don R.'s Avatar
Carefully remove any other moldings that go over the driprail ones. Working from the bottom use a small block of wood, hold it against the rolled over bottom section of the molding and tap gently with a hammer away from the car. Start at the front and work toward the back, you want to "peel" the molding off the steel without kinking it. If it doesn't want to move try some WD-40 at the molding edge. Once you you have popped the bottom edge outward it should easily detach from the top. Good luck!
Old Aug 10, 2014 | 08:50 AM
stan 65 cutlass's Avatar
use an old bottle opener with tape on it
Old Aug 10, 2014 | 11:51 AM
One option is the Search function:
https://classicoldsmobile.com/forums...oval-tool.html
https://classicoldsmobile.com/forums...stainless.html
Old Aug 11, 2014 | 12:55 PM
jankyrre's Avatar
Didn't have a bottle opener so I did it this way.Worked like a dream.Thanks.
2blu442
Body work
Oct 8, 2012 10:23 AM
2blu442
Dec 30, 2007 08:44 PM
AinoKea
Mar 18, 2006 04:51 PM
AinoKea
Feb 22, 2006 08:45 PM
