Remove and replace same door skin?
Old Mar 7, 2018 | 10:33 AM
scrappie's Avatar
Any of you body guys know if it feasible to remove a door skin to media blast both inside of door frame and maybe part of the skin and then install same skin again?
Ive never done a door skin so I don't know if its destroyed when removing?
Maybe easier to just dip the whole door if possible?
No major rust issues but surface rust on inside of door but skin is good.
Thx
Old Mar 7, 2018 | 06:57 PM
Charlie Jones's Avatar
Phantom Phixer
There is no way to remove a door skin without destroying it .
Wirebrush all the loose rust and dirt off , and paint the inside of the door with POR 15 .
Old Mar 7, 2018 | 08:21 PM
gbledsoe3's Avatar
I did it last year with great success. Let me find the pictures and post them here. I even made a tool to help gently remove the door skin around the edges. I had to rebuild the front lower corner and some inner bracing.
Old Mar 7, 2018 | 09:21 PM
gbledsoe3's Avatar
After drilling out all the spot welds, slowly work your way around the door skin lifting the edge a little at a time. It may take several times around to get it lifted enough to remove the door skin.
Bought a cheap wood chisel set and locking pliers. Cut the tip off the wood chisel and welded on the pliers.
Here are some of the spot welds that need drilled out.
The inside of the door.
Back side of the skin.
Here’s the corner I rebuilt
More reconstruction.
Inner brace after drilled out it’s spot welds. I soaked it overnight in some solution I bought at auto parts. I can’t remember but it removes most of the rust from the pits. What was too far gone, I cut out and welded in a patch.
Reassembled inner door bracing.
Sprayed everything with epoxy primer.
Back side of the door skin sprayed too.
Everything back together. Don’t forget to spot weld all around the skin where you drilled them out earlier.
Old Mar 8, 2018 | 04:42 AM
scrappie's Avatar
Thats what Im talking about! Outstanding job. Thats why we have this forum, so guys can share ideas, experiences and use their ingenuity.
Well done!
Old Mar 8, 2018 | 08:08 AM
Excellent job!
Old Mar 8, 2018 | 09:21 AM
My442's Avatar
Here is the correct tool:
https://www.eastwood.com/single-pass...hoCjEYQAvD_BwE
You can buy repro door skins too.
Old Mar 8, 2018 | 12:50 PM
gbledsoe3's Avatar
That tool is for installing not removing a door skin. At nearly $400 for a new repo skin, I choose to try and reuse mine knowing worst case, I’d have to buy a new one.
Old Mar 8, 2018 | 01:29 PM
m371961's Avatar
Thats some great work, way beyond what I would attempt.
Old Mar 8, 2018 | 04:50 PM
Gary M's Avatar
Patent that bad boy
That's impressive. How many people would rather reuse the old skin than take a four hundred dollar Chinese thin metal beating. Add me to that list.
Redog
Jul 18, 2014 09:06 AM
69442murph
May 19, 2014 05:12 AM
Danp76
Body work
Apr 13, 2012 01:07 PM
67 Olds 442
Mar 15, 2012 11:15 PM
84oldsDelta88
Dec 31, 2009 10:18 AM
