Reinstalling door glass
I am attempting to put back the door window glass in my 72 442. I removed the glass when I was doing body work on the doors when I removed them. I am now trying to put the front drivers side glass back in and now I am having a problem with the glass not crank not wanting to go all the way down because it appears that the lever(rod) that goes from the door handle to the door latch is in the way and wont allow the glass to go all the way down in the door. Unless I have that lever rod on backwards something is wrong. The passage side appears to be the same way, I did replace the door latches on both sides. I looked in my assembly manual and I could not find the door glass in the manual I have. Here are a couple of pictures of the assembly in the door with the rod under it. Anyone has a picture of the inside door assembly?
Me thinks the release rod is backwards...
Instead of that section turning in towards the window post, it should go out into the formed pocket stamped in the door sheet metal. The theory is for it to bend away from the window mount.
Is it possible you got the L and R swapped?
I looked int he body manual and no good info there - not even a diagram of this style door!
I have some pics somewhere but would need to dig for em.
The assy manual just shows the stuff to be put togeter on the Oldmobile line. The doors and trunk, etc were installed and assembled at the Fisher plant. I WISH there was a Fisher assy manual!
Okay, you do have those reversed L to R or backwards. I found this picture in my collection, looking into the left door:
I am glad I take SOOO many pictures when working on stuff!
The good part is you do not have to take the whole thing apart to replace 'em.
http://www.themotorbookstore.com/fiboma.html
Gary
Rob here is a site that shows to sell the Fisher body Manual. I plan on ordering one.
Gary
Gary
Gary, I believe Rob has a copy of the Fisher manual. I have to agree with him that there's not a lot of 'great' info in it. The section that deals with this is 7 (rear quarter) shows how the regulators go in, but not much detail on the rods.
I have 2 copies of the Fisher Body Manual. one is an original hardcover edition *bought from the library* and a softcover repro (faxon autoliterature) If you want to buy the softcover one, I'll sell it for $20.00 + shipping. It has a couple minor wrinkles on the right front lower corner - arrived that way from 'expert' Post office handling. Other than that, it's mint.
Although the quality of any repro car manual is decent, no matter which one you buy, it will never pics as clear as the original.
EDIT: Appears you both posted while I was getting my books together and comparing them. Gary, it does have some good stuff in it, just not what everyone thinks.
I had a hell of a time with my drivers glass when I re-installed it. I tried to slide it in many different ways to clear things and finally after maybe 30 minutes, it just went in! Pain in the butt. It sure did come out easy though the year before. I didn't take notes.
Have to do all my side glass and rear window. (bought new tinted all the way around and am installing OEM PW.) Now I'm going to have to take the doors off to drill the boot holes.
Allan and Ziff you are both correct about that glass. I did not find it that easy putting it back together at all. Its a 2 man job IMO.I did do one side today, the drivers side both front and back, and yes that rod was backwards. I took pictures of a lot of things when I disassemble them but did not think about the window glass.Good lesson to learn about taking pictures on just about everything because it looks like everything is not in the manuals. I am also going to have to remove the drip rail stripping because when I tried shutting the door the molding did not want to compress enough to allow the front glass to go in the channel. The weather stripping is newn but I am not sure if its Metro or not I did not keep the packaging. I ended up buying Metro door stripping because the other new stripping I had would not allow the door to close. Thanks for the offer on the manual also Allan but I dont need that one. I do have an assembly manual and also a repair manual.
Those are your window up-stops. They mount to the lower glass rail and are adjusted to limit the up travel after it seats in the hole in the door.
The pointy one goes to the back of the door. The other is towards the front but does not seat into a hole. It cannot be seen in this picture but you should find its location...
