Rallye 350 drivers fender/door gap
Old Feb 24, 2017 | 07:26 PM
jonesolds442's Avatar
Hello everyone,
After reading several other related threads, I'm hoping for some additional clarification. The pics show a wide-to-narrow gap issue and the corresponding fender-to-hood gap. The fender-to-hood is an easy fix, but the door-to-fender adjustment is somewhat confusing.
I've loosened the core-to-fender, cowl-to-fender, hood hinge, and post bolts, but I don't see how I can tilt the fender when the core-to-fender holes are not oval-shaped to allow for lateral movement.
As an aside, this gap was almost perfect before, but it had suddenly shifted because (as I have recently discovered) my paint/body man did a substandard job.
I'm reticent about getting too forceful as the remaining gaps on the car are pretty good.
Another thread suggested using a jack to tilt the frame. Someone also suggested adjusting the core support (that's the least attractive option). Several others had said just to let it go, but as you can see, this is way too obvious.
Old Feb 25, 2017 | 04:33 AM
I would think some shims under the core support would correct the door gap and shifting everything (facing the front) to the left a smidge will correct the hood gap.
Old Feb 25, 2017 | 05:21 AM
68442's Avatar
When shimming the core support pay attention to the fan against the shroud(Clearance).
Aug 22, 2019 08:45 AM
VAS442
Jun 22, 2016 04:50 PM
Cutlass455
Sep 27, 2015 01:33 PM
sklbndt
Body work
Mar 25, 2015 08:10 PM
jeffsims
Body work
Jun 4, 2014 05:16 PM
