rain gutter chrome
Use the flat end, not the pointed end. Start at one end of the trim strip and carefully pry it up with the bottle opener. I wrap the opener in electrical tape first to prevent scratches. It works great.
If you can't grab the bottom edge and roll it off with your fingers take about half a paint stirring stick or short length of 1x with a good edge and from the inside of the car hold it lengthwise and just catch the bottom edge of the molding. Tap the edge of the wood gently with a rubber hammer and work the trim loose from one end a couple of inches at a time. After it's loose on the bottom start at one end and gently pull it up and off working slowly down the length.
mcalvo
Jun 12, 2014 07:17 AM
