Need Helpful Hints on how to remove the body bolts.
I am well on the way to replacing my trunk floor and braces on my 1972 Olds Cutlass Convertable. The trunk was badly rusted and the body bolts just snapped right off. Now I want to take the front body bolts out, my floor pans are fine except for some surface rust.
My concern is that if I snap off these bolts too that I will have to cut off the floor pan braces to get to the cage nuts. This must be a common issue so how does everybody else do it?
Your best bet is to use an impact wrench, but don't be surprised if a few snap or spin. On my 66 convertible, I spun the two front cage nuts with a breaker bar and got the rest loose using an impact wrench,
i'd take a hole saw and open the floor up above the cage nut. this way you can heat up the bolt/nut, and zip them out with an impact. then either put plugs in the holes or cut out some sheet metal circles and weld them back up.
of course, this only works if you can get above them.
When i did my 72 one cage nut snapped soaked it heated it even broke off to easy outs ,after all that still had to cut hole in floor to take then out .luckly i could drill out old bolt minus three drill bits carbon ,in vise for stability and all is well back together holden tight good luck
Ground Up Restorations sells them, but i just fixed 2 of them and made a new one. http://www.ss396.com/mm5/merchant.mv...t_Code=BCN-716
JamesRustle
June 20th, 2013 09:59 AM
skryla
December 25th, 2011 07:36 AM
delta881972
July 4th, 2008 11:03 AM
