Molding Repair
Old Mar 26, 2024 | 01:26 PM
Noel Anderson's Avatar
Molding Repair
On removing my lower rear wheel molding on my 1969 Supreme Holiday Sedan, I managed to break the peg off. The chrome is in brand new condition so I am worried about maybe destroying it with heat from a propane torch. Has anyone soldered the peg back on before without destroying the chrome or molding? How else can I repair this piece? Also as you can see this is not your typical trim that uses a speed nut, but has some type of locking tang inside the blind cavity before my rear wheel which can not be accessed without cutting a hole into the well or body itself. Can anyone tell me how this clip system works in order to remove this trim.
Thanks,
Noel
Old Apr 10, 2024 | 05:38 AM
Post70's Avatar
3M panel bond adhesive. Looks like JB Weld but more expensive. Any body shop that repairs new vehicles will have it or an equivalent brand. You need a special cartridge dispenser though. If you purchase a tube you can insert a dowel into the back and push both parts on some cardboard and mix it with a putty knife. You will use it on other parts that need repairs
Dustin
cublex
Feb 12, 2023 06:45 PM
mbolds
Aug 19, 2014 06:27 PM
Chris Schoff
Body work
Jun 30, 2013 05:51 PM
Alex72cutty
Oct 9, 2012 12:18 AM
LI Olds
Jul 11, 2012 05:27 PM
