Floor & brace
Old Mar 5, 2018 | 12:01 PM
rpinnt's Avatar
Floor & brace
I pulled the carpet and found the expected rusty floor in my 64 Cutlass. The areas where it rusted out follows the middle underfloor brace, which is also rusted out. There are also man made holes in the upper passenger toe board (aftermarket A/C lines) and the tunnel has been hacked up. My parts car actually looks pretty good in these areas and I was thinking of using it for the floor repairs. Do I try to leave the floor brace attached to the floor when I transplant it or do it in steps (brace then floor or floor then brace?)
Old Mar 5, 2018 | 12:38 PM
TripDeuces's Avatar
Separate the floor from the brace. Then you can see what is actually needed.
Instead of using a spot weld cutter use a grinding wheel (not a thin cutting wheel) to grind down the spot weld to the brace and peel the skin off.
Old Mar 6, 2018 | 10:44 AM
Silverbird01's Avatar
My '65 has this problem also, I don't know where to start!
88hurstolds
Oct 7, 2015 01:29 PM
Mike Sundy
Jul 6, 2015 07:10 PM
James70convertible
Jun 6, 2014 01:39 PM
myolds72
Dec 31, 2011 02:37 PM
