decrypt the tag
decrypt the tag
hello guys
I need your help, because I'm confused swath to reconstruct the inside of my Delmont.
the seats and the carpet of color, but I'm sure the headline is something I'm not convinced.
TAG
TR 311-A
TAG
TR 311-A
If you provided all the data on your trim tag, it would help. The TR 311-A essentially gives the color of your interior and the type of front seat. I don't have the color info but I suspect the "A" means your car has a conventional bench seat up front.
Randy C.
Randy C.
I try to discover what is the type of coating that is used for cloth and vinyl seats, the color of the headliner, and more.
I searched for Delmont oldsmobile but there are no information
this is a complete trim tag
THANKS!!!!
I'll get this started, even though someone with Delmont 88 technical data is going to have to complete it as I have only "A" body info.
02D = time build code = February (02), fourth week of that month (D), or the fourth week of February 1967
S = ?
ST 67 = style/model year = 1967
3 = GM Division = Oldsmobile
54? = model series = Delmont 88 (can't tell what the number is after the "5" in the picture)
87 = body type = holiday coupe
LAN = assembly plant = Lansing, MI
4580 BODY = body number (for internal plant use)
TR 311-A = trim number/interior color & front seat type = (don't have the color code for 311), I believe "A" means conventional bench seat
P - P PAINT = lower & upper body color = pewter for both the lower & upper body colors
W = an option code that I don't have
5Y = another option code that I don't have
That should work for starters. Hope a "B" body person can come in and clean up my mess!
Randy C.
S = ?
Randy C.
I checked before writing to you after the "5" else is a "6".
S do not even understand what I can, all the links I've found the one I seem to have it.
all you have found an exact match and I thank you.
I have another code question. TR 311-A is able to discover the type of procedure, I explain, there is a date base that tells you the type of construction?
I found a very good book on ebay but I had no money to buy it and in the pages of the book you could see scraps of fabric and colors for each type of the Oldsmobile 67, I have not found and can not remember the name.
thank you so much for helping me
35687 = model series = Delmont 88 425 Holiday Coupe
TR 311-A = trim number/interior color & front seat type = Pewter (gray/silver) vinyl bench seat trim
W = tinted windshield
5Y = Deluxe seat belts
I looked at the pictures of the belts and they have the brand behind Fisher and GM all have a nice front and buckle.
"S" will be difficult to find out what it is and may be affecting the transmission
the colors of the seats are pewter and are right.
thanks!!!!
The deluxe buckle has the GM carriage and is chrome. The standard belts have the blue GM logo and are the color of the belts.
The S has nothing to do with the trans. It has something to do with the body. I believe it is time related and has to do with the month of production, but I have yet to pinpoint it.
yes, I have the belts that are chromed and the initials GM, the rear has the symbol Fisher.
thanks,thanks!!!!!!
DesertToro
January 16th, 2007 07:10 PM
