Convertible Door Alignment Wedges
Hello All,
I'm adding the missing door alignment wedges to my convertible. Anyone know which screws are to be used? They do not come with screws. Also, I noticed that there are dimples on the doors, but no actual holes for the door mounted wedge. I assume these may have been filled the last time the car was painted? Any help is appreciated.
Here's the best description I can provide for the screws that attach the alignment wedges on my '68 and '69 4-4-2 verts:
8-18 thread by 3/4" long
head diameter .26"
chrome finish
phillips drive
either a "full truss" or "round with neck" style head
Good question on if the holes were filled. I can't imagine the car leaving an assembly plant without the alignment wedges. On the other hand, if the car was re-painted at one time and the holes were filled, I can't imagine a body man leaving dimples. Your guess is as good as mine.
Good luck on finding a screw that fits the above specs! I looked around for some extras and finally came to the conclusion that I should be happy I still have my originals. If you don't find exact matches, hopefully you will locate something that's close.
Randy C.
head diameter .26"
chrome finish
phillips drive
Randy C.
Thanks very much, Randy! It seems like who ever did the restoration 10 years ago took a few of shortcuts. In addition to the alignment wedges missing, they upholstered over the rear courtesy lights, and they did not install the sway bar end link bushings. Overall it is a solid car in need of some TLC. Thanks again for the very helpful advice!
