can some one help with my cowl decoding
body by fisher
st73 3bn67lan218756 bdy
tr 327 29 A pnt
obe a65
its a 73 delta 88 royale any info would be great. had this up for a while no replies yet.hopefully you can help thanks
tr 327 29 A pnt
obe a65
I'll take a stab, but this is just a start. It appears to me that you may have copied some of the characters incorrectly.
ST 73 = style/model year = 1973
3bn67? = GM division (3), model series (bn), body type (67). Are you sure this correct? I'm thinking that it should be 36467. If it is 36467 it means 3 (Oldsmobile) 64 (Delta 88 Royale) 67 (convertible).
LAN = assembly plant = Lansing, MI
218756 BDY = body number = internal plant number
TR 327 = interior color and front seat type, which I don't have
29 A PNT = lower body color (29) and convertible top color (A). I don't have the lower body color code. I suspect the convertible top color (A) is white.
obe = time build code. Are you sure this is right? The first two characters are supposed to be numbers and the last character is a letter. If it is 06E, that means your car was built in June (06), the fifth week of that month (E) which would interpret to be the last week of June 1973, a fairly late production '73 car.
A65 = option code. I don't have that code in any of my books - my books stop at 1972.
Please re-check your numbers/letters to be sure they are correct. I'm hoping someone else can fill in the missing info.
Randy C.
Randy C.
...rcorrigan... thanks for the start you dont know how much its helping me.i did have some wrong only the obe part.its actually 08e.but the 3bn67lan218756 is what it shows.any additional help would be great.. rocket thanks also i will be lookin forward to the rest when you get a chance imma new member here and finding out fast this site is bad a--.thanks for helpin me out.
That would put its build date as the fifth week of August. The question is, which August? When, exactly, did model switchovers occur? I'm going to guess that this was a very early in the model year car built in August of 1972. I doubt they were still building 1973 models in August 1973, as wouldn't they be producing '74 models by then in time to have them in the showrooms in September?
What's the last six digits of your VIN? If it's a late model year build, it should be very high. If it's very early in the year, it should be very low. I think VIN numbers generally started at 100001, so if your last six digits are something like 100111 or something like that, it would be August '72. If the last six are something like 404432 or something else well into the several hundred thousand range, then it would be a late year build. I really have no idea. I'm just guessing.
thats exactly what i was thinkin about it being so late in the year.but if it was 72 wouldnt it have said that in the other part of the code where it says st 73. i dont have a clue eighther...last 6 in vin 11922
last 6 in vin 11922
On the date code, 08E is definitely the last week of August 1972, which is the week starting August 28, 1972. That is consistent with the last 6 VIN number of 119222. I do recall reading somewhere that the body type code changed in the '72 model year. Now, if someone could just find the trim code (327), and the lower body color and convertible top codes (29 A PNT) you will be in business!
Randy C.
Randy C.
Yup. The formerly two digit code became a single letter to free up a character in the 13-digit VIN to use as the engine code. I'm pretty sure the cowl tags kept the two digit body code for 1972 but went to the letters in 1973. The first letter was the car line (A-body, B-body, etc) while the second letter was the model code and matched the second character of the VIN.
TR 327= white vinyl bench front seat, fold down center armrest
29 29= Eclipse Blue- a dark, gorgeous metallic color.
A65= notchback bench seat
A= white convertible top. White was the default color.
DesertToro
January 16th, 2007 07:10 PM
