A body doors what fits what
Anyone know what A body doors are interchangeable. I'm talking about the frame work not the skins.
Are the door frames the same from 69-72 and just the skins make the difference ?
69 inner shells are different from the 70-72 inner shells because the edges are shaped to match the different contours of the door skins. The hard points (hinges and latches) are in the same place. 1970-up should also have side guard impact beams in the doors.
"Interchangeable" is a relative term. You can't simply use a 69 door on a 68 (or vice-versa) without major work to fit or remove the vent windows. They do, however, fit in the same door openings. Inside lock button location is different.
Or put another way. I wanna use a 71 Cutlass door shell on a 71 Chevelle and of course I would have to reskin it correct for Chevelle.
Ok, then specifically 70-72 GM A body door shells, two door, non post are the same and would work with the correct door skin for Chevelle, Cutlass, Skylark, GTO and so on ?
jensenracing77
December 4th, 2015 05:01 AM
halfmoontrail
February 22nd, 2013 12:14 PM
Limey
May 3rd, 2010 08:16 PM
pontchief
July 11th, 2007 11:18 AM
