73 omega Rear quarter damage
Old Dec 23, 2018 | 06:33 PM
Dream1996's Avatar
What should be my plan of attack here, the rest of the panel has only surface rust
-Hammer and dolly
-just cut out only bad area
- or replace whole quarter, all the way to roof
Old Dec 23, 2018 | 07:14 PM
Eddie Hansen's Avatar
How accessible is that panel? Doesn’t look horrendous perhaps get a stud welder and pull on it with a slide hammer etc definitely should be able to hammer and dolly. It all depends on how comfortable you are with body work . Replacing the quarter also involves lots of work tell us a little more about what your comfortable doing .
Old Dec 24, 2018 | 04:14 AM
Dream1996's Avatar
I think I can get to the back side ok.
I have done a little body work. I just didn’t want waist my time “trying” to straighten it out if a real body guy was to tell me Hell no. Cut it out
Old Dec 24, 2018 | 05:58 AM
edzolz's Avatar
The only real bad thing I see is the crimp just below the window. That might be harder to pull with a stud welder. I personally would not try to straighten the quarter just because of that. And unless you are real comfortable with replacing panels, I would have that part done by a professional.
Old Dec 24, 2018 | 06:15 AM
That said
I see they make full quarters for a 73 Nova? looks the same, a full quarter means that all the welds are hidden, and there wont be a big seam to fill, you will have to melt the lead out of the roof panel, then drill the spot welds,
https://www.summitracing.com/parts/o...SABEgKxrfD_BwE
this may be the best way to go,
Old Dec 25, 2018 | 10:35 AM
coppercutlass's Avatar
Chevy budget Olds powered
If the metal is in good shape repair it. Old panels are much nicer to work with . I have done worse and it comes down to how your metal skills are. What tools you have and so on and so forth. Working old metal is much nicer than new cars because these new cars have engineered steel that does not like to go back into shape. The old mild steel panels you can shrink and stretch the metal till the cows come home. If the metal is good I would not repair. Cant stress that enough
Old Dec 25, 2018 | 11:00 AM
I'm a body man by trade and love metal work. As long as i can keep my filler under 1\8 thick which is the safe margin i will repair but good metal has to he done . people see big areas of filler and think mud bucket but you can skom an entire panel. The thickness is what makes it bad.
Old Dec 25, 2018 | 07:57 PM
steverw's Avatar
Im with Copper, i would just straighten that panel. Stud puller is a good idea and hamner and dolly. Shouldnt be too difficult.
Steve
AJFink
Mar 26, 2018 12:00 PM
Innosentz
Sep 30, 2016 11:56 AM
cdrod
Body work
Jul 20, 2015 08:39 AM
AzChevs
Oct 10, 2014 09:32 AM
71boosted
Body work
Jul 29, 2013 11:00 AM
