1/4 panel extension gaskets 🤔
Old Sep 2, 2021 | 05:24 AM
72455's Avatar
1972 U code Supreme
I bought a set of 1/4 panel extension gaskets for my '72 Supreme and when I attempted to install them, I noticed that the extension won't come off unless I lower the rear bumper...is that correct, or is there an easier way?
Old Sep 2, 2021 | 04:27 PM
66SportCoupe's Avatar
No there is not.
Old Sep 2, 2021 | 05:41 PM
72455's Avatar
1972 U code Supreme
No there is not.
Ok..well then I'll put that on the back burner
Old Sep 2, 2021 | 06:39 PM
PatL's Avatar
Did you try removing the rubber filler between bumper and the extension first ?
Old Sep 2, 2021 | 07:29 PM
72455's Avatar
1972 U code Supreme
Nope...that's a job in itself. I remember putting those on,, and it wasn't that bad, but the bumper was about 1/2" lower than it is now.
Old Sep 4, 2021 | 05:31 PM
green1972's Avatar
I say NO, You DO NOT have to remove the bumper! If you remove the rubber bumper filler at the top of the bumper you can remove the quarter extensions, just put a thick tape on the tops of the bumper when re installing, also a good time to install new rubber filler! I have changed out the gaskets and have changed out the curved chromed mouldings on the extension.on a few Supremes.
Mauch712
Jan 24, 2020 05:52 AM
dynamic63
Body work
Feb 8, 2019 12:24 PM
m1369d
Body work
Feb 15, 2014 12:41 PM
woodie582
Oct 18, 2012 09:35 PM
