how to adjust hood catch on 70 cutlass
There are 2 hood bumpers toward the outside of the radiator support. You can use a 1/2" wrench to loosen up the jam nuts, then a phillips screw driver to screw the hood bumpers down a bit. If that does not fix it, you have larger issues & I'd need to see it to give more info. Some pictures of the front of the car from several angles may help us give you better info.
snookys71olds
April 15th, 2012 06:52 AM
