Trunk sending unit cover
Old Oct 8, 2023 | 08:46 AM
ourkid2000's Avatar
Good day all,
In the trunk of my 1966 Toronado, the hole for the access to the fuel sending unit is wide open. Is there supposed to be a sheet metal cover over top of that which is missing? I checked the manuals and parts catalogs and I don't see any cover.....am I missing something?
View from below - fuel tank removed.
Old Oct 8, 2023 | 11:19 AM
That's not intended for access to the sender, it's just a drain hole for when the body was run through the primer dip tank before painting. There should be a sheet metal cover over that, installed from the top and closed out with seam sealer.
Old Oct 8, 2023 | 12:26 PM
ourkid2000's Avatar
Oh ok, I guess that makes sense thanks Joe.
So it isn't screwed in (just sealed in)? I only ask as there appears to be screw mounting holes in the picture you posted. Can you still get replacements for these if I am unable to find mine?
Old Oct 8, 2023 | 02:11 PM
It's screwed in in addition to the seam sealer to prevent water or exhaust leakage.
Old Oct 8, 2023 | 03:59 PM
ourkid2000's Avatar
That's interesting. The car has no prexisting holes for those screws in the trunk. Maybe it was just sealed in place and forgotten to be screwed in at the factory. I guess I could make something up to cover it properly.
Old Oct 8, 2023 | 04:13 PM
Actually, I suspect the plate in the trunk was only glued in with seam sealer to preclude the chance that the screws would puncture the gas tank. I've seen the ones in the floorpans use screws.
Old Oct 8, 2023 | 04:36 PM
ourkid2000's Avatar
Oh yeah, I never thought of that.......bet you're right! I'll just make up a metal cover and seal it in place if I can't find the original.
70cutty
Aug 17, 2021 08:56 PM
Sid
Apr 22, 2017 07:44 AM
MarkR
Apr 29, 2010 12:32 PM
69convertible
Feb 10, 2009 10:02 PM
Pfiffle
Feb 21, 2008 06:43 PM
