Trim and window help please
Old Sep 12, 2023 | 10:13 AM
1955Super88's Avatar
I'm getting back to working on my 55 Super 88 and unfortunately due to the passage of time, lack of photos, and things getting shuffled around, I don't remember how the upper part of the trim that fits on the front edge of the hood attaches (photo). I'm aware that Fusick's carries the clips used to attach the Y shaped extensions on either side of the grill, but I'm not finding any info regarding the hood trim.
Additionally I found the driver's side vent window regulator has one of the mounts broken off. An online search only shows regulators for tri-five Chevy. They look identical to the one from my Olds with the exception my driver's side regulator matches the Chevy passenger side regulator. Is it possible that Chevy and Olds mounted them differently and they would be interchangeable?
Upper mounting holes for hood trim.
Old Sep 20, 2023 | 10:04 AM
Olds Dad's Avatar
Collector of Stray 55's
Upper ones are the same clips as the fender extensions (that Fusick sells) - lowers are just J-clips with 3/8” head sheet metal bolts
Old Sep 20, 2023 | 10:13 AM
Olds Dad's Avatar
Upper slots you have annotated use the same fender extension moulding clips that Fusick sells - lower tabs are just J-clips with 3/8" head sheet metal bolts - hope this helps
deaddds
Oct 9, 2022 10:21 AM
denf221
Body work
Feb 23, 2017 09:44 AM
Rick 357
Jan 1, 2014 11:26 AM
380 Racer
Jan 29, 2012 10:35 AM
Doug in SD
May 11, 2011 09:21 AM
