Roof rusting away
Roof rusting away
Hello all, I have a 72 cutlass S and have recently discovered that the roof is rusted through due to the vinyl top. Does anyone know a good aftermarket roof I could get to replace my existing? Thanks!
https://www.autobodyspecialt.com/cgi...on&key=CH-1418
All the repro houses sell them, so shop around for the best price. The repro panel uses the same spot weld locations as the stock roof, so if the rust is below that point on the C-pillars, you're looking at hand-fabricated patches.
A little bondo will fix that. Is there rust in other places? Cowl and rear window are tougher fixes than fenders and quarters. Others may say differently, but I see 3 options:
1. Replace the roof with an OEM donor or aftermarket panel if the rest of the car is pretty good.
2. For a low level resto, fiberglass the roof and replace the vinyl. Will never be as good or long lasting as steel.
3. Get another car. Any resto is a labor of love but a 72 S is not that rare and this one could be a bigger money pit than most.
OK 4 - chop the top, box the frame and make it a parade car.
Have you taken the headliner down yet? I hope you make out better than I did on my 442, as my front inner roof brace was rotted, although I didn't have rust through the roof skin as you have. We decided to replace the entire roof with a good used one. It sounds taunting, but it wasn't too bad a job for the bodyman I used. It went fairly quickly and was a better alternative than repairing or replacing just the front brace. Also, my rear window channel was shot. Best of luck to you.
I have yet to remove any of the headliner down but every thing looks ok as far as where everything is spot welded. And the support structure looks good too. It's just the roof skin. I like the idea of using an original factory skin but I have no idea where do find such a part. Does anyone know a junk yard in North west arkansas that might have an old car like mine?
80_Olds_Guy
August 1st, 2013 08:00 AM
oldsmobilenut
August 24th, 2011 05:11 PM
