Replacing Grilles & Headlight Bezel
Old Jun 12, 2016 | 09:29 PM
sammicurr86's Avatar
I'll get straight to it. I just got this car and love it! It's a 70 Cutlass Coupe (with 71/72 Front Bumper and Hood) Why? I have no idea. My question is can I replace the grilles with a 71/72 grille as well as the headlight bezel with a 72? Will either of them fit, is there a way to make them fit? (love the black) I've seen some 72 style headlight bezels on 70's before (Or would I have to paint 70 bezels?). I'm also planning on replacing the hood with a Ram Air Style hood.
Old Jun 12, 2016 | 10:39 PM
VI Cutty's Avatar
Why? Most likely due to an accident repair - the '71/72 front end parts seem to be more readily available. I'm currently dismantling a '70 that someone started repairing that same way.
In order for them to have achieved the conversion on your car, the core support would also have been replaced with a 71/72 version. Your current grills are for a '72 Cutlass S, (I believe). What grills do you want to use in there? Be aware that the profile of the chrome perimeter trim on the hood and grills changed from '71 to '72.
The 71/72 headlight bezels interchange no problem. You could paint your current '71 bezels or install '72s no problem.
Good looking car!
Old Jun 13, 2016 | 06:21 AM
Not even close. Google images is your friend. Note that the leading edge of the hood is completely different on a 1970, due to the different grilles.
Old Jun 13, 2016 | 07:29 AM
CRUZN 66's Avatar
Olds Fever
A little confused... You already have a complete 71/72 front end... what is there to change? The headlight bezels and grilles are interchangeable for 71/72, if that is your basic question...
Old Jun 13, 2016 | 07:44 AM
Sorry, I misread the original post. If the OP's question is, can you replace the current grilles with 442 grilles, yes, they bolt in. The 1971 and 72 442 grilles are the same except for the paint color. Same for the headlight bezels.
Old Jun 13, 2016 | 11:42 AM
Okay so just to confirm, 71/72 442 Grilles can fit on a 71/72 Cutlass?
Thanks Guys.
Old Jun 13, 2016 | 11:45 AM
Thanks Guys.
...can you replace the current grilles with 442 grilles, yes, they bolt in.
dz442
Aug 21, 2013 07:35 AM
chip-powell
Aug 10, 2013 01:46 PM
dynamic62
Jun 7, 2007 11:00 AM
