Pine Tree Sap Removal
Old Jun 13, 2021 | 09:24 PM
crzyjef's Avatar
What is the best way to get pine tree sap off the paint?
I also have some on the rear window of the convertible top.
I have tried blue dawn and goof off. its better.. still lingering sap residue.
Old Jun 13, 2021 | 09:27 PM
redoldsman's Avatar
Proud Viet Nam Veteran
Try a clay bar from Mequires.
Old Jun 13, 2021 | 09:34 PM
Soap and hot water
Old Jun 13, 2021 | 11:23 PM
coppercutlass's Avatar
Chevy budget Olds powered
Tree sap is a water based compound. Hot water and soap.
Old Jun 14, 2021 | 05:26 AM
old greybeard's Avatar
69 Cutlass S
Pine sap is bad. Fresh tar and chipped roads are the ultimate nightmare.
Old Jun 14, 2021 | 05:58 AM
Fresh tar comes off with WD40.
Old Jun 14, 2021 | 07:19 AM
Turpentine on chrome. Not sure on paint.
Old Jun 14, 2021 | 07:23 AM
jaunty75's Avatar
Old Jun 14, 2021 | 02:39 PM
Turpentine works great on chrome.
Personally, I use rubbing (isopropyl, 1-propanol) alcohol to remove pine (resin) sap.
Koda - Interesting you should mention turpentine (and, like you I don't know if it would work on paint - there are so many various paint finishes these days.) None-the-less, my point being turpentine is actually derived from/produced from pine resin/sap - it is a terpene. Turpentine may very well work, as well. There is truth (mostly) to the saying: "Likes dissolve likes"
Old Jun 14, 2021 | 02:49 PM
BTW, pine sap (either the resin or the rosin, pitch) is not soluble in water.
Old Jun 14, 2021 | 02:53 PM
ignachuck's Avatar
Frank Ignachuck
Originally Posted by jaunty75
X2 on that ^^^
Old Jun 14, 2021 | 03:30 PM
Bubble gum won't remove bubble gum...
Old Jun 14, 2021 | 03:35 PM
You have a point.
Old Jun 14, 2021 | 09:11 PM
Ice will.
One of the great understated powers of the world is a stocked 50 year old garage. There is stuff there that does wonders, with side effects if not used cautiously. Carbon tetrachloride, DDT, liquid diazinon, chlorax, gunpowder, insect powders of yesteryear, raw turpentine, acids, solvents, all sorts of fun stuff. Hell, I even have some mercury, no idea what to do with that other than a recoil tube in a gun stock.
Old Jun 15, 2021 | 05:23 AM
Regular tree sap comes off with water line Sap can be pretty thick. Actually showed our porter how to clean sap yesterday oddly enough. Wax and grease remover for automotive paint also works well and you can buy a cheap gallon of the stuff at most any parts store sometimes quarts.
Old Jun 15, 2021 | 08:52 AM
You have a point.
Tar won't remove tar either...
Old Jun 15, 2021 | 12:18 PM
Ya reckon a suitable amount of explosives would remove explosives?
Old Jun 15, 2021 | 03:29 PM
rocketraider's Avatar
Oldsdruid
Wax and tar remover should get it off. Might also try some Pine-Sol or Lestoil which both contain pine products.
Course the best solution is not park under or near the offending pine tree.
Old Jun 16, 2021 | 05:15 AM
35tac's Avatar
As an aside you might want to check in with your local fire station. They are constantly cleaning their equipment with something that might be universal. I do remember though when I was a kid in the mid fifties that the firemen used Kerosene.
Just a thought.
Wayne
Old Jun 16, 2021 | 05:21 PM
BZZBRand's Avatar
BZZBRand
Use plain ole table margarine..yup, the fake butter
Old Jun 16, 2021 | 06:13 PM
redoldsman's Avatar
I cannot imagine smearing margarine all over my car. It would take a lot of scrubbing to get that off the car.
Old Jun 16, 2021 | 07:29 PM
Kerosene is a damn useful thing. I may buy a flamethrower here soon.
Old Jun 17, 2021 | 07:45 AM
Tedd Thompson's Avatar
Koda you think like me. Goof off will work so will lighter fluid for your Zippo if anyone uses a Zippo any more. Then there is BBQ lighter fluid it's just low grade paint thinner. Most any slow dry solvent should work.... Just my thoughts... Tedd
Old Jun 17, 2021 | 12:13 PM
leftlaneonly's Avatar
Pine Sol
Old Jun 17, 2021 | 01:40 PM
Old Jun 17, 2021 | 01:41 PM
Old Dec 31, 2021 | 08:54 AM
70RocketSteve's Avatar
Rubbing alcohol. I use it at the shop all the time. Won't hurt paint. Soak a clean soft cloth and lightly rub it off. Works great. New fresh razor blade for overspray and sap on glass.
Phoenix8990
Apr 12, 2021 03:27 PM
btrbill
Feb 20, 2017 04:41 AM
DewChugr
Jun 29, 2014 09:46 PM
chip-powell
May 6, 2014 07:32 PM
ddx77
Jan 25, 2012 11:24 AM
