Need help identifying door part
Old Aug 24, 2025 | 05:48 PM
Vyse's Avatar
80's Olds Club
Question Need help identifying door part
Hey Gang! Check out the image below, i believe it's called a "door stop" on my 1983 delta 88 coupe. This one broke so now the door closes after it should and is starting to rub paint. anyone got one they could sell me for the drivers side?
i have a feeling these arent common enough to sell online, but am going to hit up some salvage yards to see if i can find a similar one, maybe from a lesabre coupe
"door stop"
Old Aug 25, 2025 | 05:56 AM
The part you've circled is the release for the seat belts. It's broken. It's the same on all early 1980s B, C, and D-body cars. Unfortunately the only ones that seem to be readily available new are for the G-body cars, and those are different. The factory P/Ns for the B-body cars are 20053526 (RH) and 20023527 (LH). I'm afraid good used will be your only option. To replace it, simply remove those two screws and the whole assembly pulls out of the door jamb. The new one just slips right back in.
Old Aug 27, 2025 | 06:35 AM
Vyse's Avatar
80's Olds Club
thank you! i've have much to learn as i get this coupe back in shape!
Jetmek
Dec 10, 2023 08:58 AM
mcc8
Feb 25, 2020 04:34 PM
Greg Rogers
Body work
Feb 5, 2013 08:46 PM
Muskrat
Alero
15
Jan 24, 2010 08:48 PM
Jakespeed63
May 5, 2008 08:08 AM
