Need help!
Old Jul 18, 2020 | 09:30 PM
Kutlass's Avatar
Need help!
I cannot seem to find a passenger side rear quarter panel bump strip (rubber and chrome side molding). I had a blowout a few years ago and the tire took it off. Year One, or any other vendor does not sell them. Please advise. Thanks!
Old Jul 19, 2020 | 05:12 AM
72455's Avatar
1972 U code Supreme
Here ya go...
http://www.fusickautomotiveproducts....number=SM701FQ
Old Jul 19, 2020 | 05:43 AM
Originally Posted by 72455
Dave - The link you provided are correct for the larger OEM moldings; however, the BSM (Body Side Molding) in the OP's image is an aftermarket (often dealership installed) narrow BSM.
Old Jul 19, 2020 | 05:50 AM
Since each dealership across the country most likely used very different BSM manufacturer's, you're going to need to dig deeper into replacement of the style BSM you are looking to replace. Here is a link (I have never purchased from this company) which provides some clarity and detail regarding the styles of BSM available.
https://www.brandsport.com/body-side-molding.html
Old Jul 19, 2020 | 08:23 AM
72455's Avatar
1972 U code Supreme
Ooohhh...did not know that. So there was factory or dealer installed BSM?
Old Jul 19, 2020 | 08:44 AM
This is what you referenced in the Fusick link. These are the OEM style BSM they are not the same as the OP requested.
Old Jul 19, 2020 | 09:43 AM
The link and the pictures above are for the 1970-1971 Supreme side moldings. The 1972 Supreme used the thin molding as shown in Kutlass's pictures. So you need to look for side molding for a 1972 Supreme. There was a good discussion about these a few months ago, with someone looking for a source for them, so doing a search of the forum should find that thread.
Old Jul 19, 2020 | 12:58 PM
Kutlass's Avatar
Hello 72455,
Thank you for the link. However, the side molding you provided is wider than the one that is on my vehicle.
Old Jul 19, 2020 | 01:58 PM
1970supremevert's Avatar
https://www.ebay.com/itm/Vintage-Sty...-/182187603426
take a peek at this? you may be able to locate some from a detailer in your area
Old Jul 24, 2020 | 10:51 AM
Cutlass BSM
https://classicoldsmobile.com/forums...ldings-121971/
Old Jul 24, 2020 | 01:19 PM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Will this help?
Old Jul 24, 2020 | 01:21 PM
LMAO Only if my link doesn't!
Don R.
May 29, 2019 01:03 PM
DK 442
Jul 6, 2016 04:05 AM
Koda
Sep 5, 2013 09:32 PM
Chris Schoff
Body work
Jun 30, 2013 05:51 PM
