Header bow replacement
Old February 16th, 2011 | 05:45 PM
pitfield1's Avatar
I need to replace my header bow.Any and all suggestions would be helpful. I've never did this before. Thanks. PIT. 69. 442 Convert
Old February 16th, 2011 | 06:13 PM
69442C's Avatar
The header bow bolts to the conv top frame assembly. There are 2 bolts on each side and these bolts are the same ones that hold the latches in place and are hard to see with the top material in place. If you partially fold the top, you should be able to look in there. The bolts thread into side rails from the top side of the latch and I believe the bolts on each side are different sizes. I believe one is a 9/16 head and the other is 5/8... can't swear to that. Just make sure you measure where the front of the header bow sits so you can be sure to put the replacement in the same place. If you still have the top fabric in place, you will need to remove quite a few staples along the front edge to move the fabric out of the way. There will also be a windlace piece stapled in the same area. And, the padding that runs front to back on each side is stapled to the front header bow. You need to undo quite a bit to do this job so you may want to thing about having a professional do it of you are not comfortable doing it. I've seen that these header bows are reproduced but I've also seen comments about them not fitting very well. Not sure if that is true or not but you may want to look into it if you were thinking of buying one.
Brian
Old February 16th, 2011 | 06:39 PM
pitfield1's Avatar
Thank you!
70convert
August 22nd, 2013 06:37 AM
68 cutty
May 29th, 2013 11:42 PM
zippy
July 29th, 2012 05:41 PM
1001coins
March 21st, 2011 06:30 PM
kitfoxdave
February 5th, 2011 03:06 PM
