Fender Brace Option - To Do or Not?
Old Dec 20, 2011 | 12:49 PM
HWYSTR455's Avatar
I purchased the inner braces that are for high horsepower cars, the braces are the ones that go inside the fender, along the cowl. Fenders are already on the car, the car's painted, and debating whether or not to install them.
Anyone have any experience with these braces? Are they worth the trouble to install? They prevent fender/cowl flex?
Old Dec 20, 2011 | 01:32 PM
stevengerard's Avatar
For what its worth, I have a convertible and I put them on anyway though the factory for some strange reason did not install those on the convertibles. Not sure how much it helps but it certainly isn't hurting.
Old Dec 20, 2011 | 01:44 PM
Gotta ask, cause I don't know. Your car has a 455? The braces were only put into the 455 cars. Probably for the reasons you stated. I'd do it if it was my car. If you need the extra stiffening and don't do it, any damage or buckling afterwards you'll just kick yourself...
Old Dec 20, 2011 | 02:26 PM
11971four4two's Avatar
MOTORHEAD
I have a set for my convert project! With the inner-fenders removed from the car they are fairly easy to install
Old Dec 20, 2011 | 04:58 PM
HWYSTR455's Avatar
So they can be installed without removing the fneder than? Like just with the inner removed? That's great info! Let me know if that is the fact, k?
Old Dec 20, 2011 | 06:15 PM
MOTORHEAD
With the inner fender out they are pretty ez to bolt in. The stud comes thru the fender in the hole in front of the hood hinge. The lower end bolts to the pocket for the body mount.
Old Dec 21, 2011 | 03:17 AM
ziff396's Avatar
Yes, with the inner fenders out, they are an easy install. I have them on mine.
Old Dec 21, 2011 | 05:50 AM
HWYSTR455's Avatar
Excellent! Thank you gentlemen!
So the general concensus is that they help, not sure how much, and are an easy install with the inner fenderwell out. Yeah, I think I'll go through the excersize and install them....
Old Dec 21, 2011 | 06:41 AM
TripDeuces's Avatar
Did 66 convertibles have these? If so does anyone have a picture of it?
Old Dec 21, 2011 | 06:52 AM
HWYSTR455's Avatar
Fairly certain only 68-72 had them, though could be wrong.
toro455
Apr 13, 2011 11:27 PM
bobb
Body work
Nov 24, 2010 05:39 AM
Ranzan
Jan 30, 2010 01:52 PM
Ranzan
lil_no
Feb 11, 2008 12:41 PM
