Convertible top mechanics
Old Feb 20, 2024 | 10:18 AM
Rob64cutlass's Avatar
Looking for advice or direction on where to find reading materials on how to set up and understand the convertible top mechanics in my 1964 Cutlass. The top has never worked since I've owned the car. It has been relatively easy with two people to close and open it and just have never got around to getting the motor and frame to function with the switch. Just looking to do some good reading on what to check first. How to test the motor. How to check the hydraulic fluid etc...
thanks
Rob
Old Feb 20, 2024 | 12:52 PM
redoldsman's Avatar
Proud Viet Nam Veteran
Look on utube. There is about anything you need to know on there. I did a pump replacement on the 54 Olds I had. Use transmission fluid. DO NOT use brake fluid because it will eat paint. It is a nasty job because you will spill fluid. Have lots of old rags ready.
Old Feb 20, 2024 | 04:12 PM
GCH
Jun 19, 2022 03:15 AM
Rocketbrian
Jun 27, 2017 04:11 PM
jjborgesi
Nov 11, 2016 11:50 AM
kbdecatur
Aug 23, 2012 03:49 PM
kaveman828
May 29, 2012 10:44 AM
