70 cutlass Tooth Angle
Old Feb 7, 2024 | 08:39 AM
70ish's Avatar
Hi, I'm in the process of installing a OEM tooth on an after market hood on my 70 cutlass. While the holes & edges match up well, the tooth seems to be bent inward a bit too much (rubbing on the grills). after lookings at many 70 cutlass pics on the internet i noticed many tooths seem bent inward, and i dont remember how my original tooth was appeared.
Question i have is, should the tooth be 90degrees perpendicular to the ground or should it have a slight bend inward at the bottom? if bent in, how much?
Thanks,
Ed
Old Feb 7, 2024 | 10:56 AM
70Post's Avatar
The "tooth" needs to be at whatever angle it takes to NOT rub on the grills. I suspect that is 90 degrees perpendicular to the ground...or possibly perpendicular to the flat "plane" of the top of the hood.
I'm assuming that your hood positioning/fitment is "good" re: front edge of hood to front edge of fenders and same on rear of hood to rear of fenders.
Old Feb 7, 2024 | 01:37 PM
70ish's Avatar
Thanks, yes the hood & hood gaps are all aligned. i put on the OEM hockey sticks to help align and it does seem to have a natural bend inward at the bottom. I wasnt sure if this was due to some previous damage or if this was by design. i can try and pull it out a bit but 90deg (yes perpendicular to the ground) seems to put too much stress on the tooth/hood connecting points.
Ed
Old Feb 7, 2024 | 03:10 PM
VC455's Avatar
Barely Registered
Originally Posted by 70ish
... 90deg ... seems to put too much stress on the tooth/hood connecting points.
I found the same. So I bent the hood attachment as far as I felt safe with and completed the 90° alignment by shimming the tooth/hood connection.
rhaberm
Jun 1, 2023 11:31 AM
rhaberm
Jul 24, 2020 04:22 PM
Bitburger
Feb 27, 2016 02:06 PM
Bitburger
Feb 15, 2016 11:21 AM
Slater442
May 19, 2012 07:39 AM
