69 conv. Trunk deck moulding
Old Jan 2, 2011 | 09:28 PM
JUMBOJIMBO's Avatar
Cool 69 conv. Trunk deck moulding
On the trunk deck where the top meets it is a two peice moulding which ends at the rear window. What's the seceret to getting it off.
Old Jan 3, 2011 | 06:57 PM
rcorrigan5's Avatar
Randy C.
This is the way I was able to remove mine. First, put the top about half way down so you can access the area just in front of, and below, the stainless trim. You should be able to detect the molding fasteners that hold the trim in place - there are 7 or 8 of them, as I recall. There should be a small phillips head screw that holds each fastener in place - you have to remove that screw for each fastener. Also, be sure to note the position of each fastener so you will get them in the right place when you install the trim. Once the screws are removed, you should have some movement in the trim. In some cases, though, a black, tarry-like sealant was used as well and you will have to work through it to remove the trim. Just go slow and easy and you will eventually be able to work the pieces free.
Randy C.
Old Jan 4, 2011 | 07:03 AM
JUMBOJIMBO's Avatar
Thanks 69 conv. Moulding
Thanks I'll give it a try tomorrow and let you know. Jimbo
ColinL
Jul 2, 2012 07:14 AM
Indy_68_S
Apr 22, 2012 03:00 PM
chris83
Mar 11, 2010 09:03 AM
chris83
Mar 4, 2010 07:36 PM
RPD1659
May 15, 2008 07:10 AM
